  1. I have converted an .avi (dvx) using TMPGE and authored
    with Tmpge DVD Author. When I tested the video in Power DVD,
    I have a video that is basically playing in fast forward.
    I don't get it.
    Also, there is no sound.....
  2. A few questions:
    What type of AVI did you try to convert?
    Is you newly converted MPEG playing normally in Media Player before you author it with TMPG Author?
    Which TMPG template/setting did you use for you convertion?
    And last but very much not least, did you read the following thread https://www.videohelp.com/tmpgenc#problems? Maybe there is already a documented solution to your problem.
    Best
    Éric
