OK here is my problem. What I need to know is there an easy way to add the subs before I join the 2 avi's. I use vdubmod to join the avi's so I can extract the ac3 and get my audio trac. The only way I can get the subs in my movie is to encode with TMPGEnc then join my 2 m2v files and then multiplex them with the ac3. When I do this I get what I want but the video says its only like 39 minutes long. So how can I get the subs in the 2 avi files before I join them so when I encode I get a m2v file that has the right time for the video? Any help would be greatly appreciated. Thanx
One day I might get it!!!!
You have got to be kidding me. No one kows how to add subs to a 2 part avi before joining the avi's? Come on some one has to know. Thanx for any help
One day I might get it!!!! -
I've done a couple of those lately. With frame rate conversion to boot, but that's besides the point.
Start point: 2 AVI files (with AC3 audio) and 2 .sub text subtitle files
My steps were as follows:
Load AVI part 1 in VirtualDub, make a note of # of frames.
Append AVI part 2.
Save AVI (no audio) and Save AC3 (direct stream copy)
Run AC3fix on AC3
Load 2nd .sub in SubtitleStudio. Add # of frames noted at step 1 as delay. Save
Load first .sub in text editor. Append 2nd sub. Save
Load 1+2 sub in SubtitleStudio and convert to srt.
Load srt in srt2sup. Save sup
Encode joined AVI to DVD m2v
Author m2v, ac3 and sup with ifoEdit.
/Mats
Adding subs to avi in virtualdub with textsub
By djgazzabhoy in forum Video ConversionReplies: 3Last Post: 26th Nov 2011, 05:04 -
Adding subs to avi format?
By Avon in forum SubtitleReplies: 2Last Post: 14th Aug 2011, 12:20 -
how to get correct aspect ratio when adding subs to avi file using auto GK
By neds81 in forum SubtitleReplies: 5Last Post: 29th Dec 2009, 18:01 -
Adding subs to a .avi file
By stgdlf in forum Newbie / General discussionsReplies: 7Last Post: 21st Nov 2009, 00:34 -
Adding Subs to Avi
By ill_kuma in forum SubtitleReplies: 7Last Post: 9th Feb 2009, 20:02
