  1. Ok I got nero and I got 3 anime eps what equal 83mins 40sec and 743 mbs. My cd-rws can hold 80mins 700(using them to test out if they will look good on my dvd player before I burn to cd-r) so I tryed and after 1 hour of it testing and trying to burn it fails and 99%. So I am wonder how can I make it burn that extra little bit I really do not want to use another cd just because I was 3mins and 40sec off and I cut out everything out(credits). So what can I do to get these extra coupe mins to work can I make nero do it or if their another program I can try what can do a good overburn?
  2. In Nero go to:
    Preferences
    Expert Features
    Enable Overburn
    Set max CD length
    Burn the disk (dont finalise the disc as this uses a few more MB's).
  3. Burn the disk (dont finalise the disc as this uses a few more MB's).
    I can not find that option were is it in nero 6?
  4. Also how do i make it so nero does not test before it burns. like i have to wait 30mins till it is finished testing and I have the test option off.
