I have noticed that for most people the lower the bitrate the better - what I am after is a set of settings to create as perfect an
encode as possible. I know that the bit-rate for DVD is avg 5MB/s with a max of 9MB/s and the resolution is 720x576 (PAL) @ 25fps.
I have seen many references to smoothing video , GOP structure, bilinear this and that - many ways to improve the encoding process - so what is the best to do.
Does anyone know the standard settings for DVD to get the best encode from DV and also Hi8 (MJPEG) captures. The size of the file
is NOT important - quality is. Is there a website or link that can point me in the right direction or can someone help here.
As a continuing point on Quality - what is the best DV codec to use. When I capture DV footage on a Win98SE system I assume that it
is using the standard Windows DV codec - is there a better one for amateur use/
Many Thanks
Adam
Results 1 to 1 of 1
ways to determine the bitrate of your dvd to xvid or h264 encodes
By codemaster in forum DVD RippingReplies: 2Last Post: 21st Sep 2011, 22:25 -
Mac Software that Encodes like a DVD Recorder
By Gypsy898 in forum MacReplies: 4Last Post: 13th Aug 2009, 22:31 -
Encodes to DVD turn up choppy
By architeuthis in forum ffmpegX general discussionReplies: 3Last Post: 22nd Feb 2009, 20:46 -
New PC - Encodes not as good...
By Browncoat in forum Newbie / General discussionsReplies: 28Last Post: 17th Jan 2008, 18:39 -
Audio sync consistently off on some dvd rip encodes
By carmat06 in forum DVD RippingReplies: 1Last Post: 25th Aug 2007, 20:07
