  1. I create subtitles as 'Individual Subtitle' into DVDMaestro.
    How extract this subtitle to subtitle file (any format)?
    Thanks for help.
  2. I can't see any export subtitle function in Maestro. However here's a trick :
    From the movie window, right click on your subtitle track and select "List all subtitles..." then click on the upper left button to select all subtitles.
    Copy (CTRL + C) then paste in Excel (for example).
  3. Thanks, is a good variant. I have copied subtitles in Ехcel, have moved columns and save in format CSV (format SubRip).
