Im looking for some advice..this is what I would like to do.
1. I have an old camcorder which uses VHS-C ..over the years I have recorded many tapes....I would like to be able to play these tapes through the computer to edit them and then write to a DVD.
2. I have many Movie VHS tapes and would like to put them on a DVD
3. Capture programs from the Televsion
Can all these things be accomplished with a capture card or editor machine...Do I need separate equipment or is there something that will do it all....Can I get some feedback on which is the best way to go to acheive these things...
Razz
Best recipe I've found:
Canopus advc-100 analog to digital convertor.
ScenalyzerLive capture s/w.
TMPGenc Plus MPEG-2 encoder s/w
TMPGenc DVD Author compile/burn s/w
Also check "How to" section on l/h side of this page. Lots of help there. -
rcb, thanks for the reply.....
So with that unit (Canopus advc-100) I could edit all my tapes like I want and also use to capture from the TV
Did you ever hear of the Matrox RT.X10
Thanks again
Razz -
I like the ATI AIW 8500 Radeon Cards. Office Depot is supposed to have the 8500 AIW Radeon Card on sale for about $60.00. If you are near a Office Depot you might want to check it out.
There are a few different, very distinct ways to do capture.
1. Analog capture using a card that can handle capturing at 640x480 or better (e.g., 720x480). This appears to be an expensive option.
2. Capture to DV AVI via Firewire.
a. Using an analog > digital converter (such as my DVMC-DA2) where you connnect your analog source (s-video or component connections) to the converter which has a firewire connection to a firewire card on your computer, or
b. Using a capture card that has analog inputs on it, or
c. Using a camcorder that has a firewire connection into your computer and analog source passthrough.
1 and 2 require that you then convert the video to MPEG-2 which is the most time-consuming part of the process.
3. Capture to MPEG-2 directly using an MPEG-2 capture card.
I'm looking into this now as I'd like to eliminate the "convert to MPEG-2" step.
Originally Posted by razzcal -
Also have a look at the ADS product line of capture devices.
analog (+dv with idvd+dv) input, realtime hardware encode to mpg in unit, sent to pc via usb. bunlded editing sW (ulead) audio/vid lock for good sync
$99 to 200+ us
http://www.adstech.com -
And my ADS Pyro A/V Link outputs to DV. Just my two cents.Originally Posted by snafu099Hello.
Capture choices
By EagleAye in forum Capturing and VCRReplies: 15Last Post: 27th Nov 2010, 12:25 -
2 choices, you decide
By MackemX in forum Off topicReplies: 1884Last Post: 27th Mar 2010, 02:55 -
Help in Hard Drive Choices??
By Ray&Paula in forum ComputerReplies: 5Last Post: 15th Apr 2008, 21:52 -
Video to TV Choices
By classic2step in forum Newbie / General discussionsReplies: 2Last Post: 13th Nov 2007, 17:23 -
Need serious help with MUSIC choices
By jimcornetet in forum EditingReplies: 0Last Post: 15th Jun 2007, 14:23
