Ok..ive used DVD decrypter to rip, then end up with like 60 files, then DVD shrink to compress..Usually what it does is it just compresses then asks for a dvdr and burns it for me automatically with no .iso needed.
What I want to know is how do i make a real dvd iso? I have isobuster, would that help? Maybe someone could post a link to a walk-thru for this?
Thanks, ive looked a lot of places =/
Oh and i have IMGTool.
Ok suppose i just wanted to compress using dvd shrink, then make an iso automatically instead of burn it right then and there using dvd shrink's burning tool, how can i do so?
www.dvdshrink.info/guides.php
To make an ISO image you can use ImgTools classic or RecordNow Max /DX,DVDShrink 3.1 will make a .nrg image which you can burn with DVDDecrypter or Nero. -
Hope you don't mind a newbie answering your question, but I just figured this out the other day, maybe it's the answer you're looking for.
You say you already have ImgTool, that's what I use.
https://www.videohelp.com/forum/userguides/152875.php
Pretty simple guide, for a pretty simple program in ImgTool. Only tricky thing is, you can't point ImgTool to the actual "VIDEO_TS" folder, you have to point it to the folder which contains your "VIDEO_TS" folder. Kinda funny the first time through, but all I did was create a temp folder named "ImgTool Temp" or some such, then put the "VIDEO_TS" folder in there, then linked ImgTool to the "ImgTool Temp" folder.
Confusing? Kinda.
Once you create the iso, burn it to blank DVD using your whatever program you usually use. My choice is Decrypter, cause ImgTool automatically opens it when it's done creating.
Hope that helps. -
Thanks for the replies, both have been very helpful.
Believe it or not, I did use IMGTOOL to try to make an iso but it kept asking for the TS_VIDEO folder (yet it created a TS_AUDIO) folder. I assumed I was doing something wrong and gave up, Ill give that suggestion a whirl and it should go just fine.
One more question about the same related topic: If i have a dvd, no macrovision, no css, and it all fits on one dvdr (basically a backup of a backup or something)..Whats the Easiest and best way to make an iso from that?
Creating a DVD with menu with several ISO files
By SandraKlim in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2011, 13:00 -
Compressing ISO files for DVD?
By mr_goodbomb in forum Authoring (DVD)Replies: 2Last Post: 5th Jul 2008, 08:32 -
Want to combine several ISO files onto one DVD. Want a menu.How?
By DRScott in forum Authoring (DVD)Replies: 2Last Post: 4th Jul 2008, 07:53 -
dvd iso/files burning problems
By CommanderZero in forum DVD RippingReplies: 4Last Post: 22nd Oct 2007, 01:25 -
How to Make Authored DVD INTO .ISO WITH TMPGENC DVD AUTHOR
By Chupes in forum User guidesReplies: 4Last Post: 19th Aug 2007, 17:38
