If I want to author an SVCD and I have for example, three files:
one is the video
and two audio files, one being normal, and the other being a commentary...
what program would be good to combine these so i can press the [audio] button on my remote to change it?
also, is it possible to select an audio stream via the disc menu?
the programs i have are:
VCDEasy
Nero 5
TMPGEnc 2.5
asdf
The two most commonly used programs for this are TMPGenc (mpeg tools/multiplex) and BBmpeg. Personally I recommend BBMpeg unless you need more than 2 streams (you can have up to four mono in a SVCD) in which case TMPGenc is the better choice. This is also all explained in this guide https://www.videohelp.com/forum/userguides/130151.php
No, you cannot select the audio in a SVCD via any menu button. You can only do so with the AUDIO button on your remote.
Super low audio. Help!
By metadog in forum AudioReplies: 13Last Post: 7th Oct 2010, 15:58 -
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 21:05 -
Audio Distortion with SUPER
By oller_a in forum Video ConversionReplies: 9Last Post: 24th Sep 2008, 14:21 -
Video with 2 Audio Streams TO mpeg1 with 1 audio stream
By Xenogear900 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 19:00 -
I used Super to convert AVI to mpg VCD...........................
By videonewbie69 in forum Video ConversionReplies: 2Last Post: 23rd Jul 2007, 11:34
