I can't figure out why I get this error because the AVI file seems fine, but it won't load into TMPEGenc. I tried restarting my computer, and I ran the ripped files through DVDtoAVI again, but no luck. I haven't had this problem before, anyone have any ideas?
need more info..what type of file are trying to load into TMPG?..the d2v file??
i had a similar prob and i think i needed a filter or something, did that and it worked ok
Option> enviromental setting> VFAPI> set direct show multimedia file reader to higher priority, helps often.
Next time save the dvd2avi project and load that as video source in TMPG. -
Okay thanks. Save the project huh. Got it. Thats different from the method the ripping guide suggests. Thanks for the help. I'll do both of those things. I actually thought I was low on memory, but I re-did the DVDtoAVI a third time, and its encoding fine right now. Thanks and Aloha!
TMPEGenc h.264 conversion error
By iGnight in forum Software PlayingReplies: 2Last Post: 16th Jan 2011, 11:14 -
vob2mpg error: Could not get interfaces No such interface supported
By Lowell in forum Newbie / General discussionsReplies: 1Last Post: 3rd Dec 2009, 00:48 -
TMPEGEnc DVD Author Ordinal Error
By justin81 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2009, 21:33 -
Converting from flv to any file supported by quicktime
By alanswartz in forum ffmpegX general discussionReplies: 6Last Post: 24th Feb 2008, 19:23 -
TMPEGENC keeps closing itself because of an error
By Akhet in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2007, 01:38
