I'm able to rip a DVD to DVD-R, just want to know how to rip to DivX with the subtitles included in the DivX file, and which player can support DivX file with subtitle?
It sounds like you wan't to have the movie and selectable subtitles in the same file, thats not possible (as far as i know
However there are two options you could go for, 1. Permanent Subtitles, the subtitle are encoded into movie with noe way of disable it.
2. Make an avi with preffered codec that contains the movie and a seperate subtitle file in your preffered format.
Information for these things can be found here on this site or at doom9.net
(btw: I think you might find Gordian Knot handy.
Good Luck
10110101100111012011 <- The bug Bill doesn't talk about. -
thanks man, but where can i find specific how-to posts? doom9.org just has way too much stuffs to sort out what i really need. and by the way, i'd go for the permanent subtitles, as i think it should be easier that the second way you mentioned, right?
Please TRY post in correct forum. I'm moving you to the dvd to avi forum.
try http://matroska.org/, this has selectable subs and audio, dunno if its any good tho.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
search for autoGK
free program
The electronic components of the power part adopted a lot of Rubycons.
Rip DVD including subtitles using vlc
By skeptic_always in forum LinuxReplies: 10Last Post: 22nd Sep 2013, 22:19 -
Rip a part from a dvd with subtitles
By itoo73 in forum Newbie / General discussionsReplies: 5Last Post: 13th Feb 2011, 15:20 -
How do I rip subtitles only from a DVD in OSX?
By jakeknotts in forum MacReplies: 2Last Post: 1st Mar 2010, 21:22 -
How do you rip subtitles from a DivX file w/4 subtitles
By JoeBolden in forum SubtitleReplies: 2Last Post: 21st Nov 2007, 15:46
