Im using Windows XP....just recently upgraded my pc to a P4 3gig processor...1 gig of ram.
My Sony DRU-500A will not read a dvd burned with data such as mp3's, pics,etc. And when I go to my computer...under the name of the drive it says DVD-RW Drive...but under type it says CD Drive.
I upgraded to the latest firmware...which I believe is G dating back to October. Does anyone have a clue how I get this back to reading dvds? Pleeeease help! Even with movies now it seems to not open them or it will open them but it will be in folder form.
I also use Nero 6 if that has anything to do with it.
Please HELP!
Nero+sony 500a =bad combination ,the reason I say this is because for some reason these 2 dont get along....
well the thing is it has worked before on my other system...and I have had this same issue on my other system...just cant remember what I did to fix it. ARRRRRGH! Why dont I write things down!!! I cant remember if Nero had anything to do with it or not. I dont see why it would unless it overwrites a file or something...somebody please helllp!
DID YOU APPLY EITHER THE NERO or THE ADAPTEC ASPI UPDATE?
this will fix you up
I used a file called aspi_471a2.exe from the ADAPTEC WEBSITE
Not Showing Network Drive
By esrylx in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 3rd Aug 2009, 13:57 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 12:52 -
External drive not showing in Device Manager
By alegator in forum ComputerReplies: 15Last Post: 10th Dec 2007, 13:38 -
Extra Hard drive not showing up in my computer?
By Ghtpua in forum ComputerReplies: 8Last Post: 27th Nov 2007, 23:19 -
Sony DRU-820A DVD Drive suddenly burning slow
By progrocktv in forum DVD & Blu-ray WritersReplies: 3Last Post: 24th May 2007, 22:55
