I've recently discovered that VirtualDUB is running quite slow on my newer P4/2.8 machine compared to the second P4/2.67.
After looking at the CPU utilization while doing a DUB, I realized VirtualDUB utilizes only 50% of the CPU.
I am using version 1.5.10 under WinXP SP1 and with a HyperThreading CPU.
Anybody else noticed this?
The more I learn, the more I come to realize how little it is I know.
Anybody???
The more I learn, the more I come to realize how little it is I know. -
The only time I experienced something sililiar was when I was dealing with captures. Huffyuv and MJPEG to be specific. Normally VDUB isn't constrained by I/O performance, but with a 20 GB source it easily has I/O issues.
Try turning hyperthreading off, it doesn't gain you anything with VDUB, and it's probably the source of you 50% CPU utilization.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Episode 6 Bug? Or Quicktime Player 7 bug?
By NY2LA in forum Video ConversionReplies: 3Last Post: 25th Jun 2012, 16:59 -
Bug in VirtualDub (?) -- can't cut desired number of frames
By ralf07 in forum Video ConversionReplies: 3Last Post: 21st Sep 2011, 17:50 -
Virtualdub batch job changes filter settings back to default. Bug?
By gll99 in forum Video ConversionReplies: 5Last Post: 5th Apr 2009, 22:41 -
AutoMKV Bug .........
By RVD2720 in forum Video ConversionReplies: 11Last Post: 14th Mar 2009, 00:26 -
Possible Bug?
By CurtisMinBC in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 25th Jul 2007, 03:55
