I need some advice/help with mpeg to vcd.
1. Firstly the cheapest and/or best programme to use (Is there such a thing as a freebie)
2. Do all mpegs need to be burned onto cd-r at the same session.
3. Is it a good idea to join mpegs together and burn as one track or as seperate tracks.
In reply to your questions:
1.) Load of freeware programs obtainable in the tools section of this website. Panasonic MPEG Encoder is often said to be the best (my favourite as well, but costs $$). TMPGEnc, is second best and free.
2.)CD-R's after burning are usually closed i.e. finished.
3.)You can keep them seperate or join them - up to you. Would however say it's better to leave them seperate, then you can skip forward to the next clip. You can join them in the burning/authorizing program itself by making the pause between them 0 (zero) secs. -
thanks for the assistance. will the TMPGEnc do the whole job of transferring and burning mpeg to vcd on the cd-r.
TMPGEnc will only convert your video to mpg format. You'll then need a seperate program (like Nero) to actually burn the VCD. I recommend Nero because it has to support burning in VCD format.
Need help authoring DVD from VCD mpeg files with dual audio..
By siratfus in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2010, 04:31 -
Need mpeg-1 to VCD tool that splits
By anadiner in forum Authoring (VCD/SVCD)Replies: 14Last Post: 4th Dec 2009, 04:24 -
Fixing corrupted MPEG-1 VCD (freezing issue)
By headless chicken in forum EditingReplies: 11Last Post: 4th Sep 2009, 22:55 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 16:28 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 12:25
