I bought 2 80mm coolermaster fans. http://www.newegg.com/app/ViewProductDesc.asp?description=11-999-051&depa=1
The screws are thick and the holes in the fans don't have any spiral shaped grooves for the fans. Am I supposed to manually drill in the screws to create the grooves, or am I missing something?
If you just straighten a paperclip and ...
J/K
Nope. Screw fans are self-tapping !! Just screw them in. -
I tried, but the screws are the same width as the holes, and because of the grooves in screw, I can't push it in..
it's kind of hard to explain thru typing
lol, paperclip -
I assume they look like this ...
The screws will require a little force and will create their own grooves as you screw them in and apply pressure. They have to be screw/pushed in and cannot be just pushed into place. They will not go in by themselves by merely turning them like tapped machine or case screws.
They do not go all the way through the fan (i.e. through the front and rear holes). The merely are long enough to either mount though the case and to the fan or to mount fanguards.
Yeah -- hard to picture with words. -
That's what I meant by manually screwing it in - creating the grooves.Originally Posted by Ripper2860
So then they will be sticking out of the rear of the case (or wherever i put them) ??Originally Posted by Ripper2860 -
You screw them in from the outside of the case and into the fan to mount the fan to the case. So - yes, the screw heads will be on the outside of the case and the threaded part of the screw will go into the fan.
Ok, i'll put some more pressure this time and try. Thanks alot
If you still have issues, compare your screws to the pic I posted in the above thread. Those are the type that I am referring to and are "standard" fan screws.
If yours look radically diffreent, then it may be a different ballgame.
pioneer cld 3070 laserdisc - transit screw - simple question
By TurboJoe in forum DVD & Blu-ray PlayersReplies: 0Last Post: 15th Jan 2012, 22:06 -
Newer FFDSHOW versions screw up audio sync for me - why?
By TigerSoul in forum Software PlayingReplies: 7Last Post: 26th Mar 2010, 16:26 -
Power Supply to Fan
By HotDamn! in forum ComputerReplies: 9Last Post: 23rd Mar 2010, 04:13 -
Q Fan in BIOS
By wingfan in forum ComputerReplies: 1Last Post: 24th Mar 2009, 12:44 -
Fan noise
By alintatoc in forum Newbie / General discussionsReplies: 6Last Post: 10th Feb 2009, 10:48
