Hi
I have this DVD, Solaris - PAL UK. I want to remove the extras, if I do this then the main movie and the menu (which I want to keep) will be just under 4.37 G without any re-encoding.
The problem is that the DVD starts off by playing trailers which are contained in the same VOB files as the Extras (behind the scenes etc). I would like to know the best way of removing the titleset while still having the menu with the DVD starting at the menu.
I am a newb and think I can use ifoedit to alter the VIDEO_TS.IFO but I dont know how to do it. Or can I use InstantCopy or similar to remove it. I was hoping it was a simple case of deleting the unwanted VOBS but of course that would be too easy.
Any help would be greatly appreciated.
