  1. Hey everybody,do any of you guys know how to create a VCD using Arcsoft Showbiz? I tried using format 'Video CD disc' and file type 'Mpeg1' but when i burned it,it didn't work on my Bush 2023 player! Would it be better to get DVD-R instead to add mpegs 2 and watch on my DVD player? I'm using CD-R,other formats or file types did not work on my DVD player! Although could it be the fact that i used CD-R vinyl? Please help! How the hell do i use Showbiz?
    R.Dixon
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    Did you try playing your disc on the PC?
  3. Please do not cross post - One topic is enough, other topic closed.
    /Moderator - Bugster
    EDIT: 4 posts on the same topic is three too many. If you don't know which forum to use, pick the one that seems appropriate, if it is wrong a mod will move your post. Do NOT post the same question multiple times.
