A few Weeks ago, I was backing up a dvd using RecordNow, when my computer crashed. since then I have been unable to use recordnow, when I start the program it just hangs. I have tryed uninstalling and re-installing it a few times, but it does the same, the splash screen opens and then, it just hangs, nothing against Nero, I love it, it's just I got used to RecordNow. anyhelp, with this problem would be appreciated, running XP. if that helps.
Have you tried using it's bigger brother Record Now Max 4.50 ?.
A 30 day demo can be got from here....
http://www.softlandmark.com/RecordNowMax.htm
Scroll down to the bottom of the page, look for the stpRNM450e_STPD.exe.
It might solve your problem.
Apart from that i don't know what the cause could be.I Have Always Been Here
Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H
