Hi I'am using the sony DRU500A and I'am also using NERO 6 ULTRA EDITION 6.3.0.2 All I'am tring to do is make a simple burn. Nothing fansy. So far i've burned the disc using dvd shrink3.0 into a folder. now i don't know how to burn the files to a blank dvd using nero. could someone either exsplain it to me step by step or lead me in the right direction to read how to do this.
thanks for your help, but i don't know what type of nero version your ysing but with this version it's not that simple need more info thanks again
Use the guides, they are your best friend in this type of situation. All of the guides can be found on the left hand side of the board in the green colored area.
Try this one:
http://www.polarhome.com:793/~afonic/nero.htm
It should give you all the information you need to complete the burn. All pictures and instructions are included.
I am not trying to be rude in saying this so please do not take it that way, just next time try to do some research before posting. The answers you seek can often be found in the wealth of information contained on this site. If at that point you still have questions, by all means please post and someone will try to help you.
Best of luck to you friend. -
Actually it IS that simple.
1) Open up Nero using the Start Smart menu.
2) Choose the DVD tab at the top right, then navigate to, and click on DVD-Video
3) On the right, locate your DVD Shrink files
4) Drag those files into the VIDEO_TS folder that Nero provides on the left
5) Click on BURN
BTW...when u provide your version info and someone tells u how to do it, you can be reasonably sure they will give u instructions that apply to your version instead of theirs. -
thank you everyone i'am a new newbie at this. thanks again for taking the time to exsplain this
NEWBIE Burn HD DVD
By Wally 2007 in forum Newbie / General discussionsReplies: 7Last Post: 10th Aug 2011, 21:10 -
Trying to burn a dvd using dvd shrink and Nero 10, please help a newbie?
By KtuluAlly in forum DVD RippingReplies: 6Last Post: 30th Dec 2010, 14:33 -
Have windows 7 and am tring to get video off sony cam but doesnt work.
By intheory in forum Newbie / General discussionsReplies: 4Last Post: 16th Mar 2010, 19:17 -
newbie,i have a problem,i burn a dvd on playback i get stutter when panning
By goldenbhoy in forum Newbie / General discussionsReplies: 10Last Post: 28th Apr 2008, 15:00 -
Newbie Question: Can I use Alcohol default settings to burn DVD-5?
By ShadowRider in forum DVD RippingReplies: 1Last Post: 11th Aug 2007, 15:56
