I have one hard drive dedicated to 'Work in process', ie Video capture, clips, etc. When I check the 'Properties' for that drive it says 12.1 GB used, however, there are only two files on there and indivually they total 5.98 GB- what's going on here? This is not the primary drive. And there are no partitions. The 'Total Drive Space' in properties is correctly stated as 38.2 GB (40 GB HD less swap).
Empty your recycle bin. There's a good chance that you have large files in there that are associated with the drive. It sounds silly and so simple, but the files are still on that drive till they are emptied from the bin.
It could be many other things, but lets make sure to knock the simple stuff out of the way first. -
It could also be SYSTEM RESTORE data saved to the HDD if SYSTEM RESTORE is enabled.
--- and --
A HIBERNATION file (equal in size to the amount of RAM installed) if HIBERNATION is enabled.
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Converting 2-Disk Sets to 1 Disk
By 1337assassin in forum Newbie / General discussionsReplies: 18Last Post: 23rd Oct 2010, 09:53 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27 -
Baffled!! Titlewriter shows nothing but DVD Player shows Movie Name
By Subhash in forum Authoring (DVD)Replies: 16Last Post: 25th May 2007, 12:02
