Hello People, Just want to do a small servey asking you which Software u use to convert your DIVX / XVID files (700MB in size approx), What PC Specs u have (intel pentium 4 3.0GHZ 1GB Memory ETC ETC) And the time it TAKES you to convert a movie from DIVX/XVID to MPEG 2 format...
Thanks for your time!!
I have a 1.2GHZ AMD 512MB Ram, uing TEMPENC PRO it takes me approx 5 /6 Hours to convert a 700MB File.
Should you not base this survey on the playing time of the AVI as opposed to the file size? You could have an AVI with a playing time of 30 minutes (therefore only 45,000 frames to transcode) or two hours (and so 180,000 frames to transcode), and both files being 700MB long.
Let's apply some simple maths to gain a meaningful figure. You calculate your speed (for the people who don't like maths) by:
Total time of transcode in minutes divided by total playing time of AVI in minutes.
My machine is a P4 1.5GHz with 512MB of PC133 RAM, and scored 2.786. The file was 2 hours 11 minutes long (131 mins) and the transcode took six hours five minutes (365 mins).
I hope this is right - my maths isn't so good after a few pints of Guinness!
CobraDMX
EDIT: Sorry, forgot I was using TMPGEnc and the input was a DivX 5.0.2 encoded file! -
CobradMX: What were your settings? CBR,VBR or CQ? If you used 2-pass did you cache the first pass? What template/resolution? What search precision? Any filtering?
There's too many variables that can affect the encoding time, especially filtering and search precision. Unless the settings are the same then comparison becomes meaningless.
"Art is making something out of nothing and selling it." - Frank Zappa -
I have an Intel P4 HT 3GHz and 1 Gig of RAM. I'm afraid I don't use the software that you do, so the the valid statement I can make about it's performance is that it's VERY VERY FAST.
Even my spare machine, an Athlon XP2200 with 768 Mb of RAM, is QUITE QUICK.
My best computer is a vintage 1970's Commodore desktop calculator with illuminated red display. Never more than arms length away from my mouse, it calculates bit rates WITH ASTONISHING SPEED! -
ZippyP,
Well, you can't say I didn't try! It's SVCD standard, CBR, high quality motion search.
It's a lost cause I think. Perhaps it could be a new feature of this site. If someone made a list of all the variables that people could fill in and it would automatically generate a score for their machine. It wouldn't be perfect but it would at least be a rough guide.
Anyways, it was worth a go.
CobraDMX -
I see a lot of posts from people that complain that TMPGEnc is too slow and it turns out they're using the highest precision and filtering as well. As far as hardware goes, it's the CPU that most affects conversion times. And you can't be doing anything else at the same time as that robs CPU cycles. Yes, apparently there are other programs that are faster, CCE and Mainconcept spring to mind. I do most of my encoding when I'm away from my machine so a few minutes or hours here or there don't really matter.Originally Posted by CobraDMX
ok Restarting thi again, With no filters etc etc, Just a plain DIVX/XVID to MPG-2 Using the wizard Constant bitrate
Takes me 6 hours approx with TEMPGENC, How long does it take u?
What i want to know/find out is the FASTEST Record of converting with decent quality picture/sound?
Quickest ive heard is a 700MB approx 1 hour and half file taking 4 hours....
anyone any qucker? If so what PC Specs u got?
ps anyone used procoder?..
Which CPU specs to go for?
By A Traveller in forum ComputerReplies: 42Last Post: 13th Aug 2011, 13:26 -
Youtube specs
By tokintmash in forum EditingReplies: 7Last Post: 23rd Aug 2010, 11:44 -
What should be specs of PC
By cyberlion in forum EditingReplies: 26Last Post: 6th Jul 2010, 08:50 -
Best LCD TV Specs
By SIRCOOKS in forum DVB / IPTVReplies: 5Last Post: 18th Oct 2008, 04:03 -
Help on laptop specs
By Tbag in forum ComputerReplies: 10Last Post: 4th Aug 2008, 09:26
