Ihave a problem with the new version of DVDShrink.
It reads the dvd in the drive, but when I hit "BACKUP", the following message apperars:
"DVDShrink encountered an error and cannot continue. Copy protection error. The request could not be performed because of an I/O device error."
I have check marked the "Region Free" box.
Seems this version does not disable copy protected dvd's. I say this because I tried this new version with both an original dvd and a copied dvd, it worked fine with the copy but not with the original, that's when that message comes up.
I never had this problem with the previous version.
I have to use DVDDecrypter first in order to use DVDShrink 3.1.
Has anyone had this or similar problems and if there is a way around it, what can I do?
Thanks![]()
Yeah I noticed the same thing - I also noticed that if you remove a part of the DVD (i.e. the "coming soon to dvd" section, which in my case was VOB_03) then it comes up with an error saying that vob_03 is missing. Shrink 2.3 didn't do this.
That problem has to do with Nero. see this thread.
http://forum.digital-digest.com/showthread.php?s=&threadid=30480
Problem with DVDShrink
By abba1961 in forum DVD RippingReplies: 3Last Post: 22nd Mar 2010, 01:52 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
problem with DVDshrink and vista
By sweetness in forum Newbie / General discussionsReplies: 8Last Post: 24th Jan 2008, 16:32 -
Problem with the the DVDShrink Step
By ism33 in forum SVCD2DVD & VOB2MPGReplies: 31Last Post: 21st Nov 2007, 16:09 -
Problem with dvdshrink
By malleus in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2007, 21:03
