Hi,
I'm using Toast 6.0 (am downloading the 6.0.3 update as I type).I'm trying to create a dvd from various video files the majority being mpegs.Toast will import them just fine but when I make the dvd image there is no audio with the video files. Anyone come accross this ? Thanks in advance.
Results 1 to 11 of 11
I've had problems with Toast 6.0.3 that seem to be related to both path resolving issues and size. I would try putting the source file at the root directory of my startup disk before sending it to Toast. If that didn't work, I would try also demuxing and give Toast the video and audio files separately. When you tell Toast to open a video file, it will give you the opportunity to locate the accompanying audio file.
Encoding MPEG2 on any machine single processor, sub-1ghz is brain-numbingly slow. You can expect 3x the divx movie duration on up for transcoding to DVD.
I drop a divx movie into toast no problem.I can even preview the movie in the small windows.So I click on make disc image and the cursor starts spinning.I think that it must be encoding so I leave my powerbook on all night.The next morning the cursor is still spinning and there has been no progress.Has anyone managed to import and encode a divx into toast and actually burn the dvd ?
Both the audio and video codec used to make the divx must also be available to Quicktime and Toast so it can decompress and transcode.
When you say available, do you mean the divx file must be able to open with Quicktime ? I have a divx codec installed that should enabe Quicktime to play divx.
"should" ... but does it? When you open this file in Quicktime, do you see smooth-playing video and can hear audio? Your chances of a successful conversion in Toast are directly related to this file being able to play well with Quicktime.
MPEG StreamClip - H.264 MP4 w/AC3 audio loses audio
By the_wallcrawler in forum Video ConversionReplies: 5Last Post: 25th Jan 2014, 04:05 -
Final Cut Pro imports .MPG's with no audio.
By Benhermies in forum MacReplies: 2Last Post: 20th Sep 2009, 17:09 -
MKV to DVD -- audio loses sync
By Dr.Rock in forum Video ConversionReplies: 15Last Post: 30th Aug 2009, 04:51 -
MPEG StreamClip loses audio
By alhenderson in forum DVB / IPTVReplies: 16Last Post: 31st Jan 2009, 13:10 -
PinnacleStudio8 LOSES AUDIO during import of .AVI files
By DivXterminator in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jun 2008, 09:43
