what would be the best bitrate option for encoding a 2 hour movie onto 2 cd's while keeping a the best quality. I mean bitrate option in terms of CBR VBR CQ Multipasses etc. I have been using the CQ setting with TMPGEnc using AVI2SVCD but my disk space will not allow the CQ setting suggested after the CQ test. i have to run the CQ test first and then see what the projected file size will be then set a set CQ setting accordingly. is there a better way to do this?
is there a CQ calculator?
Results 1 to 1 of 1
FFmpeg's Bitrate Tolerance Option...
By raymng in forum Video ConversionReplies: 1Last Post: 13th Mar 2012, 09:08 -
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
