OK, I've made a little droplet converter to extract .pdi disk images made on the PC to .iso images the Mac can work with. This is based on pdixtract, part of PDITool, which is distributed by InstantCopy, I believe, as open source. You can grab your very own copy here. Use it by simply dragging .pdi files onto the app icon, which will prompt you to choose an output folder and name the iso image.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
Oh yeah, and I've never tested this, so if someone has a .pdi file handy, could you let me know if this works? Thanks. I'm pretty sure it's working ok, it's just that I don't have any .pdi files to be 100% certain. It should pass on the processing to the terminal, and convert the image there.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
OK, I've put a spiffy icon on pdi2iso and put some brief instructions with it. I guess since no one here has .pdi files to test with, I'll just post straight to VT, and see what the flood of bug reports brings. There's a known bug by which if there's a space in the path to this application (like the disk name or any of the folder names leading to this application), it will not work. The new version is here:
http://homepage.mac.com/wiseweasel/I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
hahahaha....you're really going all out on these pdis! If I still have my pdi files I'd test it out.
If you have a PC you could *ahem* download InstantCopy and create pdi images, then test your droplet. -
I don't, so I can't. I just saw that there were no (GUI) PDI conversion utils for the Mac, and thought it would a good learning experience to try and make something. It was a pretty simple project, and I haven't gotten any complaints yet on the VersionTracker page for it, so I assume it's working.
compare iso image with DVD/CD
By perfection in forum Newbie / General discussionsReplies: 14Last Post: 26th Jun 2011, 12:38 -
Blu-ray disc structure to iso disk image
By llee782 in forum MacReplies: 2Last Post: 12th Feb 2010, 02:22 -
Saving ISO image file?
By Mort439 in forum Authoring (DVD)Replies: 12Last Post: 28th Mar 2009, 11:17 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27 -
ISO M4A converter to wav
By illyad in forum AudioReplies: 4Last Post: 14th Jul 2007, 23:12
