I finally had time to transfer a recorded show from my Panasonic E100 to my PC. I burned the two hour show in the DVD-RAM , transfered the .vro image to the hardrive of the PC, and edited the commercials with Mpeg Video Wizard (nice sw btw). I then exported the show as mpeg2. I am using Sonic Foundry's DVD Architect (or is it Sony now?) to make the DVD. However it tells me that the mpeg2 must be re-encoded and at this rate it will take it 10 hours on an Intel P4 2.4 ghz machine with 1gb of RAM. Is this normal? Could I have missed a setting on DVD Architect to speed up the encoding ( have updated DVD Architect to latest)? OR should I be looking for a different DVD authoring software to use? TIA.
Ulead DVD MovieFactory 2 has an option to not convert compliant MPEG files. Check your DVD authoring software to see if it has a similar option. If it doesn't, I suggest you give MovieFactory a try.
Ripping TV show DVD's
By rmas71 in forum DVD RippingReplies: 10Last Post: 12th Apr 2012, 21:25 -
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 04:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
more then 1 show after authoring?
By Desert Flame in forum Authoring (DVD)Replies: 5Last Post: 15th Aug 2009, 17:01 -
dvd recorder does not show up
By hitenmdesai in forum DVD & Blu-ray RecordersReplies: 10Last Post: 25th Jul 2007, 14:04
