Ok this is the first time I am making a menu and the first time I am burn something to play on my dvd player.
I have ready to go vcd anime eps. All I need is a menu program I have tryed so many and their all to hard for me this is what I need.
I just need a program what can do this
1. very very very very very easy to use
2. auto load up the menu when cd is in dvd player
3. I can use the arrow keys on my dvd controler so I can scroll down or up(since I will have 4 eps on a cd)or if that is too hard to make or will just come when I got the menu numbers will do fine
4.If I hit the root menu button it goes back to the menu
Thats it that all I want just that. I need a program what can do that I do not want to spend more then like 10-15mins on this.
Results 1 to 16 of 16
Try Sonic MYDVD. It has a easy menu for DVD. My program came with my Sony camcorder.
read the rules, please:
Please try not to bump your topic(reply to your own topic) immediately, wait at least a few days.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
gee thxs for that great post...................could not even offer any advice also thxs for bumping my post.
Oh, I see you're out of time. -
God another moron has posted. God...........what is it with you people.Do morons only responed here??????
Originally Posted by hoho12
2. Wouldn't that be a function of the dvd player, not the disc?
3. Check the VCD spec - is this possible? I thought VCD specifications limited you to number entry.
4. See #2 and #3 - is it supported in the VCD spec, and is it a function of the disc or the player?
Also, what software are you using for creating your VCDs? Does it not have menu capabilities in it already? How will we know, if you don't tell us what it is?- housepig
Housepig Records
out now:
Well it is not the acutal menu I do not how to make it is how to get it to auto run. As far as I know I need something to tell it to start it up. Like it needs to know what to do so I am thinking I need to put some code or find something what can make it run. Because if my dvd player can handle that format and it should be able to able to load up that menu(if it works like you said you think it works as)
Nero can make the menu very easy just pop in the back ground put the name in your done but it does not auto load and go back to the menu. Also they should be able to handle it that would be a sad format if it could not do this.
Ya I found about that a little while that vcd can not handle with the scroll but that is not too important what I am looking for it how to get it to auto start up and go straight to the menu and some way to get back to the menu once your in the film thats all I am looking for. -
If you want useful replies give useful information. Also don't just inform people of what you want and expect them to hop to it.
Actually I'm one of the guys who usually tells others not to give newbies a hard time but you seemed particuarly rude and demanding to me.
"I want this and I want it now"
You then insulted Housepig when he gently informed you of one of the rules around here. He's being quite a sport and helping you anyway. -
If you'll read the rules of this forum some time, you'll find out that it's best to do a little searching on your own 1st before asking questions which, to some more seasoned folks, are not only obviously answerable but also extremely impatient.
Does anybody remember Veruca Salt in Willy Wonka?
Sorry, now that I've gotten that off my chest, I'll get down off the soap box. It's just that this site gets mounds of these type questions daily and it's very tiring.
ANSWER: You can't program your DVD player to autorun VCD's. It completely dependent upon the (unchangeable) firmware of that particular model of player. But, if the VCD is authored correctly (VCDEASY and knowledge/experience), all you'll have to do to get it to play correctly will be to push the [PLAY] button.
Oh, yes. On more very important thing. It would be wise of you to refrain from showing your ungratefulness by ridiculing others.
Scott -
Look at TMPGenc DVD Author, it has a simple easy to use layout and has preset menus that will let you do what you want, and in future you can also fairly easily create your own
The others suggested are okay, but are fairly limited in what they can do
Personally I'd go for something that isn't as 'point and click' I prefer to be able to have some control over what is going on, the others are too simple looking and make out that we are all idiots
My choice, and I've tried quite a few DVD authoring applications
DVD-Lab for simple/intermediate/advanced and very future proof authoring
TMPGenc DVD Author to get you started, and still be able to do authoring that looks acceptable and will do exactly what you are looking for -
steptoe,
I agree that TMPGEnc DVDAuthor is very good, but hoho12 did mention in the 1st post that he had VCD episodes and was looking to burn CD (not DVD). Sorry. -
Well now I have lowered my standards now all I want is something that can make it so that when I pop in the cd and it loads up the nero menu and I can use the root menu controll that all I want now what program do I need to do that.
nvm I found out that if your dvd player does not auto start it then you can not have that option with the vcd and vcds do not have root menu option.
http://www.latexlair.com/products/vcds.html
which is the best Program for making Youtube 'music' Vids?
By snadge in forum EditingReplies: 1Last Post: 11th May 2011, 13:00 -
Help with making menu's!!!!
By BananaKing in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2011, 07:55 -
Inexpensive easy to use program for making videos
By edbulmer in forum Newbie / General discussionsReplies: 5Last Post: 14th Dec 2009, 18:00 -
dvd menu and sub menu program
By mikeoliver1313 in forum Authoring (DVD)Replies: 7Last Post: 20th Jan 2008, 11:31 -
making custom dvds (program)
By tk187 in forum Authoring (DVD)Replies: 9Last Post: 4th Sep 2007, 08:41
