Folks:
The tool "mplex" which is distributed with mjpeg tools doesn't complain when I try to multiplex MPEG-2 audio with MPEG-2 video, but won't let me put PCM audio with video.
I'm trying to get the video ready for a DVD and I want to include PCM stereo audio, which (according to the spec) is the lowest common denominator for audio on NTSC DVDs.
Is there some tool that will let me mux a PCM audio stream with MPEG-2 video?
Robert
Your DVD authoring software should do this for you as part of the authoring process.
Hi raswirsky,
Alternatively, you could use ffmpeggui to convert PCM (WAV) -> AC3 (192 - 256 kbps will be sufficient) as (I believe) AC3 is also a standard audio format for DVD's.
Might wanna check if it's OK for NTSC - I make PAL and it's OK on those...
Of course, as previously mentioned, your DVD authoring software should work with PCM.
Hope that helps...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
"I'm trying to get the video ready for a DVD and I want to include (PCM stereo) audio"
You don't need to and should not multiplex video and audio before authoring dvd.
This is the job of your dvd authoring app.
Extract Audio and video from Multiplex karaoke DVD and re author
By quebecLA in forum Video ConversionReplies: 1Last Post: 8th Jul 2011, 22:01 -
Can't play PCM audio from MPEG made from MKV
By brianp6621 in forum AudioReplies: 10Last Post: 19th Oct 2009, 12:12 -
No 48kHz options in MPEG-Layer 3 in VirtualDub and Mod
By ashwin.terminator in forum AudioReplies: 24Last Post: 6th Apr 2009, 14:07 -
Multiplex SD Mpeg with ac3 audio
By hartless in forum DVB / IPTVReplies: 8Last Post: 9th Sep 2008, 06:59 -
32khz mpeg to 48khz how to ?
By Videodream in forum Capturing and VCRReplies: 12Last Post: 4th Aug 2008, 09:11
