I'm new to backing up DVDs and wanted to know if you have to use a program such as DVD Decrypter to rip the DVD to hard drive before you use DVD Shrink to transcode? Is there a way were DVD Shrink can rip the DVD to file mode? Whats the fastest method?
to build on this:
I was using decrypter to rip the main movie files only. Can I do that with DVD shrink? or do I have to rip the entire DVD? -
You can rip title sets as well as chapters or certain time periods. Check out the "RE-AUTHOR" mode.
next question - this is taking me up to 2 hours to do with my burner (iomege super dvd). Any way to speed up the process.
If you using your burner to rip the dvd, remember most are locked @ 2x when ripping which will slow the process quite a bit.
Errors on Shrink ripping latest hit dvd's
By bluzjamer in forum Authoring (DVD)Replies: 9Last Post: 6th Dec 2010, 00:13 -
question about dvd shrink
By marlo in forum Authoring (DVD)Replies: 5Last Post: 29th Aug 2010, 04:22 -
question about DVD Shrink
By Bamahusker in forum DVD RippingReplies: 7Last Post: 1st Mar 2010, 20:48 -
How to shrink the file size of 7.63GB after ripping the DVD?
By coy228 in forum MacReplies: 6Last Post: 16th Jun 2009, 09:19 -
question regarding analyze in DVD Shrink
By Bamahusker in forum Newbie / General discussionsReplies: 2Last Post: 8th Jul 2007, 08:31
