I've got a 700MB AVI file that I've been trying to add subtitles to and I get them on there and everything goes fine until I goto encode it so they are perminate. If I encode it with the default VCD setting in TMPGEnc I get a perfectly good mpg but its about a gig now in size. I'm trying to keep it at 700MB so I only have to use one CD. If I use a KVCD template I don't get any sound with the file thats outputted. Any ideas?
Check the AVI file and make sure it is stereo. Once you have stereo, you can go back to KVCD. Or you can also use the wizard in TMPGEnc to make an XVCD, if your player can play them. And of, course, you can also split the video between two disks.
Hello.
Keeping subtitles in 2 lines from original .txt file in Subtitle Workshop
By Valerc in forum SubtitleReplies: 3Last Post: 10th Feb 2012, 06:45 -
Resizing and joining two avi files and keeping file size down
By wayc00lio in forum Newbie / General discussionsReplies: 5Last Post: 16th Feb 2011, 10:18 -
Adding subtitle to xvid without increasing file size of the .avi?
By Kromgol in forum Newbie / General discussionsReplies: 3Last Post: 19th Jul 2009, 12:03 -
re-encoding vid file for smaller size but keeping same format?
By WidowMaker in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 13:56 -
Best way to go from MJPEG (1280x720) to small file size keeping quality
By Mysteriouskk in forum Video ConversionReplies: 7Last Post: 27th Nov 2007, 16:21
