Recently I purchased the above mentioned modem as I had heard a lot about US Robotics modem for Indian Rs.1,500/-(US $32 approx.). I find this modem in any way superior to other Internal modems such as D-Link,Dax, Microtek etc. The connecting speed is 44 KBPS which is exactly the same I used to connect with my earlier D-Link Internal modem. The bundled Control Center Software does not recognise the US Robotics Modem and so I am unable to use the software. I have updated the driver using the supplied CD.
The Specs of my computer:
Pentium 4 2.4 Ghz 800MHz
Intel D875 PBZ
Corsair Memory 256 MB DDR-SDRAM 400 Mhz
N Vidia TNT 64 32 MB AGP
Adaptec Firewire card
Samsung 7200rpm 40 GB Harddisk
Samsung Combo drive(DVDrom+CDwriter)
OS Windows XP Pro Service pack 1
Are there any other users of this particular modem ? What shall I do to rectify the problem ?
vsenapati
XP should've found that. But since it didn't try the old fashioned "Add/remove hardware option under the control panel
Also go to the Manufacturers site and get the latest driver, if you can connect to the net on another computer.
How to Change your Voice to another normal Voice
By UmmAddan in forum AudioReplies: 2Last Post: 21st Jul 2011, 17:00 -
anyone here use online fax service?
By lordhutt in forum Off topicReplies: 3Last Post: 18th Jul 2009, 15:11 -
What Model of other Brand->Lite On Model ???
By kevin215 in forum DVD & Blu-ray WritersReplies: 0Last Post: 26th Nov 2008, 05:44 -
help, anybody knows any kinds of software that can do fax on the pc
By flowerhorn in forum Newbie / General discussionsReplies: 7Last Post: 13th Oct 2008, 20:51
