Results 1 to 16 of 16
  1. New Firmware released today for 811 and 411 drives.
    Match more media
    http://www.liteonit.com/ODD/english/english-load-firmware.htm
  2. Banned
    Nov 2002
    Pgh Area
    But does this firmware allow the bitsetting tool to be used?
    I upped to FSOG, have not had a problem, yet. They pulled that one after a week or so.
    I'll DL it, before they pull it again.
    Cheers,
    George
    texas
    Yes the bitsetting still works and now so does 2.4x +rw's
  4. Banned
    Nov 2002
    Pgh Area
    Good to know, thanks, Kirpen.
    Cheers,
    George
  5. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Good news, being new however to bit settings I'm not really sure when to do it. Still good news that I can upgrade to an offical one that supports it, I'mstill using the pulled one.
  6. Banned
    Nov 2002
    Pgh Area
    Flaystus,
    I'm not SURE when to use bitsetting, either, but since all DVD players have to recognize the ROM format, seems that if your player won't read a DVD+R, then it will read a +R set to ROM.
    I'll know this works when I try one in my daughter's Samsung M101. The player list to the left has reports that it will read anything, but it has never read a single thing I have burnt, VCD/CVD/SVCD/X/DVD-R/DVD+R/DVD+RW.
    Nothing but bought/rented disks.
    Have to take one to her house and try.
    Cheers,
    George
  7. Yeah, my parents have a old Toshiba 2 disk dvd player that has a known firmware that prevents the playback of any recorded media even cd-r. With a dvd+r set to dvd-rom I was finally able to get a recorded disk of any type to play in this player.
  8. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Yeah but my question is do you bit set before or after the burn? I just don't understand WHEN to do it. And haven't had time to play around with it yet.
    Of course I'll have tons of time this next week, cause I'm on vacation.
    canada
    Use the bitsetting before you do a dvd+r burn.
  10. Using Nic's DVDInfoPro, you can:
    *Set booktype before burn = DVD+R
    *Set booktype before/after burn = DVD+RW
    Set default DVD+R booktype to DVD-ROM
    Set default DVD+RW booktype to DVD-RW
  11. Banned
    Nov 2002
    Pgh Area
    Flaystus,
    I don't know what they said, but I burned some DVDs for my g'daughter, + an -, and asked her to play them in her PS2, and she misunderstood, and tried them in her portable, you know, 5 or 6 inch screen? She said they hung, glitched, refused to play, whatever.
    Reburned MIB with bit set to DVD-ROM, gave it to her tonight, she said it played perfectly. Not an expensive player, her aunts pooled to get it for her and her brother.
    Bitseting must run in the background, and has to be started each time you go to burn.
    It seems to work for me, will know for sure when the youngest's Samsung accepts something I have burned.
    Did you see my post about Staples having the Pac Digital ( I think LiteOn ) 8X for 129 after 25 buck rebate?
    Cheers,
    George
  12. I'm a Super Moderator johns0's Avatar
    canada
    DVDInfoPro bitsettings only work with ricoh drives.Liteon bitsetting app doesnt need to run in the background while burning,just set the drive to dvd-rom and close the bitsetter and the dvd will be burned with the settings,its just when you reboot you have to apply the bitsetter again.
  13. Banned
    Nov 2002
    Pgh Area
    JohnsO,
    Turn it on, set the bit, burn?
    I think I tried to say not auto start. You boot it each time you burn, set the bit, shut down, boot it back up the next time.
    Cheers,
    George
  14. I'm a Super Moderator johns0's Avatar
    canada
    gmatov,yup,just run the bitsetting program and set it to dvd-rom and then close it and burn.You only need to set it each time you reboot.
  15. Originally Posted by johns0
    It also works with NuTech and NEC drives.
  16. I'm a Super Moderator johns0's Avatar
    canada
    Gil T Pleasure,doesnt make any difference here cause it still dont work on liteon drives.
