I am new to the dvdr game so bare with me. I have captured a movie in mpeg-2 format through my hp dvd movie writer and it is to big to put on a single dvdr. I have looked around the forum and found alot of helpful posts for this problem. I used Rejig to shrink the file and demux the audio. Then I used Ifoedit to try to get the audio track back with the video and there is where my trouble is. I keep geting (Ifoedit error) "additional data required but no free space in input buffer"!! I cannot find a buffer setting to make it larger. Is there any other way to get these files back together without using Ifoedit?
You might look at TMPGenc DVD Author.
If your captured mpeg file is only slightly larger then the 4.3 gig max size, TDA does have a mpeg editing function that can let you trim/edit to get a smaller sized file.
If your file is considerably oversized, you can either split it with TDA to burn two disks... or just go ahead and compile the single big file into VOB's, etc and then use DVDShrink to resize.
WinRAR MPEG(video file) Compression Gone Haywire
By hech54 in forum ComputerReplies: 4Last Post: 20th Mar 2012, 14:13 -
YT audio compression
By -Sandro- in forum Video Streaming DownloadingReplies: 0Last Post: 26th Oct 2010, 07:25 -
WMV vs. MPEG compression artifacts?
By smexxy in forum Video ConversionReplies: 5Last Post: 16th May 2009, 23:33 -
Audio Compression
By Nitro89 in forum ComputerReplies: 8Last Post: 2nd Oct 2008, 09:00 -
I am at my witts end trying to reverse MPEG-4 compression. Help!!!
By forensic in forum Video ConversionReplies: 9Last Post: 30th Apr 2008, 12:16
