I like to backup my DVD's keeping the main menu and the main movie (also sometimes some of the extras if good).
To do this I use DVD Decryptor and then use DVDShrink. On most movies this works but I have noticed that if the movies have a short film or "Coming Soon" bit before the menu comes up and I remove this short film or advert then the DVD never finds the main menu, the DVD goes into the machine plays a little (i.e. warnings, etc) and then stops when it should go to the menu.
I thought using DVD Decryptor that if you remove things then the DVD is re-mapped so not to look for the removed files but my DVD's seem to look for the file and then stop instead of ignoring it and going to the menu.
For films that go straight to the menu I have no problem as there are no files to remove.
Can anyone help - or suggest a better program. I have read a few guides but you seem to have the choice of movie only or whole DVD, I only want generally the film and the main menu.
Just run direectly through Shrink and tun what you don;t want to stills. WHen playing just hit skip or next to go past all the junk. The other choice is to reauthor and just choose the main movie which what I do for maximum quality.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Another option is to replace what you don't want to see with few blank frames. There are few ways to do it, one is explained here: http://menuedit.dimad.net/ht_me_replace_cell.html
Read this guide from the "Guides" section of this very website:Originally Posted by cooksj76
http://www.polarhome.com:793/~afonic/clonedvd.htm
It explains how to use CloneDVD to backup the main movie and preserve the menus. It works great for me.
Ripping Blu Ray Disc to DVD with same menu and chapters
By MI6 in forum Blu-ray RippingReplies: 2Last Post: 10th Sep 2011, 08:35 -
MKV to dvd while keeping the dts audio intact
By Loonatik in forum Authoring (DVD)Replies: 13Last Post: 30th Mar 2010, 10:41 -
Converting a DVD to AVI with all menus intact
By beatsntoons in forum Newbie / General discussionsReplies: 4Last Post: 17th Dec 2009, 14:39 -
How to spilt one DVD to 2 DVD (5) with meuns intact
By c1steady in forum DVD RippingReplies: 4Last Post: 16th Apr 2008, 12:05 -
Xvid to DVD with aspect ratio intact?
By StratPlaya in forum Video ConversionReplies: 12Last Post: 5th Jul 2007, 13:02
