I thought i was getting pretty good at using tscv. I have been able to make 3 movies (7 discs) with menus,chaps,intros, and extros. This last one i had a problem with. in the past everything has been NTSC Film 23.97, the one i am having problems with is NTSC 29.97. I set my chapters, i go to create with menu generator and somewhere past 20:00 mins the frames freeze, both the source and the vfapi .avi file have a clean bill of health. What gives? I am using tscv's lastest release and the newest vfapi. Any ideas people?
When it comes to freezing then you need to frameserve the avi with virtualdub to tscv. i have never been able to get my chapters from not freezing at about the 27 mark so i frameserve and it works great. Just load your mpeg in to dvd2avi and create a d2v file and then make a avi out of that and frameserve it. it should only take a 1 minute to set it up for framesreving.
thanks i'll give it a try once i figure out how to produce enough temp drive space for it, thxs again
okay, i've got the space again, i've never had to frameserve before so i have no clue where to start. Anyone have a how-to or could explain it in simple terms?
there ya go...happy the guide helped
TSCV on Vista
By mrcoolekin in forum Authoring (VCD/SVCD)Replies: 4Last Post: 11th Feb 2008, 23:04
