I use nero 5.5 to make my VCDs. I put them in all the right formats (NTSC) and when i put it in my DVD player it says VCD then spits it out.
ANy ideas why it's doing that?????
Which exact version of Nero are you using 5.5-0.8?,1.8?,2.3? 2.4?
This could be one of your problems.
Another problem could be the encoder used - Panasonic MPEG Encoder is more compatible with DVD players.
CD-R layers don't seem to be a problem with your DVD Player as it is meant to take all.
.srt won't work on my Phillips BDP3200/12
By madsboe in forum DVD & Blu-ray PlayersReplies: 7Last Post: 27th Sep 2012, 05:48 -
Blu ray player (Phillips BDP2700/12) won't play some movies.
By lema1610 in forum Authoring (Blu-ray)Replies: 8Last Post: 12th Oct 2011, 07:48 -
Phillips DVDR3575H 37 won't record OTA??
By Gritz in forum DVB / IPTVReplies: 5Last Post: 2nd Apr 2008, 09:11 -
Will a Phillips DVDR3475/37 play DVD +R DL discs?
By c5vetman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Nov 2007, 11:47 -
Insignia portable DVD player can't play VCDs
By Amuse in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2007, 19:28
