I have a set of 20 .avi files that I would like to put on DVD to be able to watch them on my tv. I have tried going through the How-To's, but I'm really not even sure which one to read.
If anyone can help me out, I'd greatly appreciate it. I'm not sure where to start.
Thanks.
Well, you will have to read a few before you know what you need. There is no real way around reading.Originally Posted by sublimelax
Jeff -
I've got TMPGEnc Plus 2.5, but don't know how to use it.Originally Posted by Tommyknocker
You will also an authoring program like Nero Express, to burn your DVD.
Anyway, go to the Convert section and find a guide that shows you how to convert AVI files to MPEG DVD with TMPGEnc. Then take your MPEG file and have Nero Express author and burn it to a DVD.Hello. -
Check this guide out:Originally Posted by sublimelax
http://dvd-hq.info/Compression.html
...I find it VERY useful for explaining and helping to refine the settings in the TMPGEnc. It talks about doing the video only. The bitrates I use are:
Max = 9,200
Average = 6,000
Min = 2,000
I extract a WAV (audio) from my DV AVI using VirtualDub and convert WAV -> AC3 (@ 192kbps) using ffmpeggui.
Then combine (mux) the 2 when authoring using TMPGEnc DVD Author and get excellent quality results.
Good luck. Hope that helps...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Another DVD Speed Newbie Questions
By bobelk99 in forum Newbie / General discussionsReplies: 3Last Post: 16th Jun 2011, 01:25 -
Help putting AVI files onto a DVD!?
By rightsidebrain in forum MacReplies: 10Last Post: 24th Mar 2009, 09:40 -
Newbie Questions DVD to ????
By swezey in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2008, 10:19 -
Newbie questions on converting avi to mpeg2 and dvd authoring
By mlcampbe in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 14:08 -
Putting two AVI files on the same DVD
By Mr Sorrow in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 27th Oct 2007, 08:57
