I just installed my new dvd rw and all the software that was with it. When I place a store bought dvd in the drive it will not play. The drive is recognized by the computer but nothing plays. Should not the software included " intervidio winDVD 4" allow me to play the dvd? When I attmpt to play the dvd I get an error message telling me to lower myscreen resolution and or color depth. I have the resolution at 600*800 and the color quality at 16 bit but I still get the same message.
Thanks in advance Bob
from the "play" guide ( see l/h column):
in Windows
To play a DVD you need a software DVD Player, then it is just to insert the DVD in your DVD-ROM and hit Play using any player like PowerDVD or WinDVD.
To play MPEG2 with Windows Media Player you need a software DVD Player installed or a MPEG2 Codec.
To play a copied/ripped DVD you can use WinDVD, rip the entire DVD folder VIDEO_TS with for example Smartripper or DVD Decrypter to a folder called VIDEO_TS on any harddrive root like F:\VIDEO_TS. Then start WinDVD and select F: as the DVD Drive. To play a copied/ripped DVD with PowerDVD you click on the open button and choose Open DVD File from the Hard Disk Drive and open the video_ts.ifo.
in Windows
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28 -
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
DVD will play on new DVD player, but won't play on old
By joe8915 in forum Video ConversionReplies: 9Last Post: 18th Feb 2008, 19:57 -
Can a dvd player that able to play dvd+r dl play dvd-r dl or does this vary
By dymx in forum DVD RippingReplies: 1Last Post: 22nd Oct 2007, 12:30
