Anyone know where I can find a short video clip of static video, like when your cable comes uplugged from the tv or whatever. Just need a short clip, I could capture it I guess from my own tv, but if someone already has one or knows where to get one that would probably be easier. Thanks
Make one yourself. Use this script with AVISYNTH 2.5 or higher to give yourself a pseudo-noise clip. This one works pretty good, but experiment with the settings until you are satisfied.
LoadPlugin("d:\program files\HOLDER\mpeg2dec3.dll")
blankclip(length=240,width=720,height=480,fps=24,p ixel_type="YV12",color=$FFFFFF)
addgrain(80000,0.5,0.5)ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Oh, sorry. Get the "ADDGRAIN" plugin at:
http://mywebpages.comcast.net/trbarry/downloads.htm
More good work by Tom Barry.ICBM target coordinates:
A lot of work? Hell, I did all of it for you.Originally Posted by watyeagICBM target coordinates:
For Developers ; Video Sample having TWO AC3 and PCM, with en-SUB
By Bonie81 in forum Latest Video NewsReplies: 1Last Post: 13th Oct 2010, 01:30 -
Need help in deinterlacing an old VHS converted video (Sample included) ..
By ahmadka in forum RestorationReplies: 22Last Post: 30th Jun 2010, 13:43 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 11:26 -
How to calculate the sample size of wmv Video file
By asifjavaid in forum Video ConversionReplies: 3Last Post: 13th Apr 2009, 09:33 -
Detecting static/noise in video
By tripecac in forum EditingReplies: 10Last Post: 17th Jul 2008, 08:53
