  1. i have a movie clip that is in divx format. and its about 4 min long, and i want to compress it as low as i can, and i get it to be like 40 mb when i use virtualdub and divx compression with low settings..??
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    What is the size of the clip you are trying to compress, and exactly what settings are you using now?
