  1. PLease help me to convert PAL mpeg files to NTSC. Thanks.
    Mar 2003
    california
    This seems pretty time comsuming and complicated. If you want to spend the money, try the following Pal to NTSC or vice versa software www.focusinfo.com/products/firestore/dvconversionsuite/dvcsuite.html
  3. I am fairly new to this but I have gone out and spent a small fortune on software. Can any of the following applications do this a little easier???
    Adobe Encore
    Adobe Premiere
    Ulead DVD Movie maker 2
    Stomp Record Now Max
    Pinnacle InstantCopy
    DVD X Copy Plat
    I also have these others
    Alcohol 120%
    DVDDecrypter
    DVD Shrink
    DVD Copyone
    DVDR Easy
    and a few others
    Can any of this stuff do the conversion instead of going through all of that other stuff?? After searching the forum I cant really tell.
    Thx for your help
  4. considering most things broadcast in PAL are actually just NTSC film speeded up you should be able to just open the file up in TMPGEnc and re-encode.. Tell me if I'm out of my mind here, but this should work, right?
