I was screwing with V-dup and av synth... installed them, then tried to uninstall them..
Now, My Vfapi will not convert a .d2v file or a .tpr file...
I am completely stumped now...
how can I dump the registry settins for the avi file handler and then use the VFAPI?
I use win2k professional... amd 1.4 gz, 256 ddr ram 60 gig hard drive...
I have been able to convert .tpr files to .avi files with vfapi until I started screwing with v-dub and av synth... I was able to compress and make an .mpv file too... now I can't really sucks...
how to clean or reset ?
Thanks in advance.
Sincerely,
Mike
mikldom
Sounds like you need to run the UNINSTALL portion and REMOVE of Vdub's handler...
Well I figured it out..
I did run all the uninstall handlers...
exception of one... run the endproxy.reg file in the avi folder of v-dub... did that, and no more problems..
Thanks tho for the thought..
Mike
VFAPI Codec Problems
By [K]eep[A]way in forum Newbie / General discussionsReplies: 20Last Post: 8th Sep 2011, 06:40 -
ffdshow codec not showing up in Virtual Dub
By uglijimus in forum Video ConversionReplies: 2Last Post: 8th Mar 2010, 15:12 -
MKV to AVI in Virtual Dub With AviSynth :?: :!:
By ineedhelp123 in forum Video ConversionReplies: 28Last Post: 21st Jul 2008, 15:08 -
Will my video work with no prob with divX codec
By Remyisme in forum Newbie / General discussionsReplies: 3Last Post: 7th Jun 2008, 05:48 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
