hi all
hope someone can help, i just did a file scan of my pc using norton antivirus 2002 (all upto date with definitions) and found no viruses, so i then used the AVG anti virus and found a virus called
trojan horse downloader.istbar.au
but it couldnt be removed, so i put it in the AVG virus vault. I cant find no instructions on symantecs website or any other reference to remove it. Can anyone help, i really dont know why i get so many viruses, i have 2 scanning softwares and a firewall.
kas, thanks
I could not find any information on that virus. I looked at Norton and Mcafee's websites. I did a google search on it and similar names. The only thing I was able to find was a google cached reference to a TrojanDownloader.Win32.IstBar.au virus that was identified 1-6-04.
It looks like whatever it is, it was just identified and not all virus scan softwares have been updated to idenitfy it or remove it yet. I'm sure more details will emerge as it is more widely identified. It looks like for now the virus vault that it is quarentined in will have to do. -
thanx maestro5050 for your reply,
i guess i cant do anything but to keep checking for updates, thanks anyway.
kas -
kas187,
When you open Internet Explorer, does it load a normal homepage (one that YOU select) or a porn page? Is this what it is?
Have you run Spybot Search & Destroy on your system? If it is Adware, then Spybot should rid you of it.
Norton AV 2002 is pretty old -- are you sure you are running with the latest virus definitions? I'll bet that your subscription has expired and you are actually running with the latest def's as of your subscription expiry. -
Exactly what I was going to say adaware should get rid of that for you
Go to Trend Micro's website. http://housecall.antivirus.com/housecall/start_corp.asp
At trend you can scan you PC on line and it will clean the virus if you wish but the best part is once the scan is done and it finds one, it takes you to a page where the Virus name is a link to a page that tells you all about the virus, tells you how dangerous it is, what it does, how it travels, other file names for it...AND how to get rid of it. Walks you through it step by step complete with Registry edits and all.
AND best of all it's FREE!!!
If you are still on a dial-up, relax for a while because it will download the definitions and it takes a bit but the scan is done from your own PC, so after the definitions download you can surf while it scans. -
@ HillJack
thnks for your reply, but i dont think its the virus you think i checked it out the programme files and there is no entry of it. i also have Ad-aware 6.0 it found a few objects and deleted them however that was before i ran the original sacn yesterday, ill try again.
@ northcat_8
thanks for the link, ill check it out now,
thnks again guys.
kas
Question about virus so terrible that Ghost restore did not kill the virus
By jimdagys in forum ComputerReplies: 24Last Post: 27th Apr 2010, 11:58 -
what is this virus
By romanstopme in forum ComputerReplies: 14Last Post: 12th Feb 2010, 18:50 -
Virus or something else?
By alintatoc in forum ComputerReplies: 12Last Post: 1st Oct 2009, 03:57 -
VIRUS,VIRUS, Getting blocked accessing antivirus sites
By G)-(OST in forum ComputerReplies: 11Last Post: 10th Apr 2009, 03:40 -
virus or something else
By alintatoc in forum ComputerReplies: 3Last Post: 2nd Mar 2009, 15:37
