Results 1 to 13 of 13
    Argentina
    I have the ME version of windows. Should I change it, or there is any other way to fix this up?
    Please help. Thanks
  2. whats up cristian? let me tell you i have ME. ME has whats called FAT32 which only allows up to a certain file limit. i have tried everything except reinstalling. someone on here said to format the drive to _______ but i don't remember what it was and even then i don't know if it would work with WinME. maybe when someone reads this they can tell us which OS doesn't have the FAT32 cause i don't remember. i sure as heck would like to capture unlimited.....
  3. AVI files have a 2 Gb size limit.
    There is no solution to that.
    Most applications work around this limit by creating a new file every 2Gb.
  4. i use iuVCR. the size limit i get for an AVI is 4gig. when it hits the limit its done till i restart the capture.
  5. Alucard2050 you are probably thinking NTFS (Windows 2000,XP, NT)
    Try capturing with Virtual Dub using the multi-segment capture option (set it up for file no bigger than 2gb)
    If you have more than 1 HD you can also use the spill-over function
  6. thats my other problem. can't capture with VDUB. get the error no device drivers(VFW). and yah thats it NTFS.
    Argentina
    Hi and thank you all for your support.
    Anyway, I've been told that VirtualDub isn't as great as AVI_IO. Don't you know if AVI_IO will capture the same way as VirtualDub?
  8. AVI_IO captures multisegment like virtualdub and has a nice feature which puts dropped frames as full frames (makes it easier for programs to read the avi). You can also open up all AVI_IO the segments automatically in virtualdub and then framserve to something else. Virtualdub gives you more control though.
  9. Member ashtones's Avatar
    Aug 2001
    I hear a lot about this program av io. It's not free is it? Is there any guarentee it will work with my Pinnacle DV500? I would hate to throw money away.
  10. avi_io has a free 30 day trail (has some limitations though)
  11. I thought the limit was 4 gig. I've captured several files 3 gigs and up. I currently have two 2+ gig avi's on my harddrive. Maybe it's a WinME/98 limitation. My 3 gig captures have been on a Win2000 OS.
    Darryl
    Aug 2001
    San Diego
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    That is true.. To a point. Old style avi codecs have a 2GB limit. OpenDML avi codecs, on the other hand, have no such limit. HuffYUV, for example, works fine up to around 5GB (and then chokes.. prob due to a bug)
  13. NTFS may remove the 2-4 Gig AVI file restriction...but a new ballpark opens up regarding video capture card drivers...W2k is notorious for this...i hope this prob is rectified in XP
