Is this possible or what? I've been searching this forum, the web, and everywhere else - I've even bought the "open your mpeg-2 in Quicktime"-key from Apple, but it won't export...
Any apps, anything that'll work?
Trying to fit some footage onto a DVD-R, but forgot to calculate before converting to mpeg-2, and I've erased the original files and tapes...
Thanks in advance
I don't think that there are many OS 9 users on this forum anymore...
Anyone??? -
Video on OS 9 is dead (not that it was ever that alive). OS X and open sourced software have lured everyone to greener pastures. This being said, I think you can do it with the QuickTime MPEG2 Playback component and the MPEG2 Exporter from DVDSP. You open the m2v in QT Pro, export the entire thing to DV, then add the video to the sound track, and trim as necessary, and then export the video and audio back to DVD format. At least that's how it works in OS X, and I believe those components are available for OS 9. But seriously, if you're doing any work with video, you'll be much happier with the solutions available for MacOS X. If QT can't export from m2v to DV, there's always MacMpeg2Converter.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
Changing AC-3 Bitrate (Problems with AC3gain)
By dabas in forum AudioReplies: 3Last Post: 30th Jan 2010, 14:55 -
changing bitrate on existing wmv
By Stevenroy in forum Newbie / General discussionsReplies: 1Last Post: 17th Oct 2008, 19:04 -
Changing AVI Bitrate!
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 5Last Post: 8th May 2008, 11:23 -
By kotton in forum AudioReplies: 5Last Post: 1st Sep 2007, 22:29 -
By kotton in forum Video ConversionReplies: 2Last Post: 1st Sep 2007, 21:05
