I'm using a Blue G3 iMac (OS9.2) and am trying in Final Cut Pro to export to M2V using the QT MPEG2 component. I get an error message telling me my G3 hasn't got Altivec support and therefore can't encode.
I know that Altivec support exists in G4 upwards, but does anyone know if there's any workaround for me, as I don't want to have to take my HD into work to use my eMac (OSX) each time I want to encode!
Results 1 to 9 of 9
unfortunately.... i dont think there is a "work around" as you pointed out its G4 chips and above....
apparently bitvice do a version of their mpeg encoder specifically for the G3
you could save a reference movie from fcp and then run that thru the bitvice encoder...
possibly. -
I'm not sure why it won't allow you, (someone may have a tool to deactivate the warning, but processing will be very slow). The only workarounds I can think of are the Heuris MPeg encoder, or the slower way of exporting a regular MOV file (probably using the animation compressor - or anything you'd like to save the best quality; possibly DV, as final cut may just output it without recompressing).
There is also "Cleaner" Bitvice, and MegaPeg - I just know these make MPEG2, not that you could directly export from Final Cut. You can find that stuff at www.versiontracker.com Even on that older slower machine, I would recommend beefing up the ram, and giving OSX a try. There are many more sharewares and LOTS of freewares, as OSX can run only slightly modified linux programs (if at all), and there's a huge following there. I have 2 older G3 computers (iBook and iMac DV 500) that are running OSX, and they're fine. I turned off the extra animations, etc. and it feels very smooth, even on the aging machines... and your computer will never crash. Well, okay - almost never compared to OS9, and you'll need that. Plan on letting your machine process at least a full day or so. -
Hmm... Maybe I'll try OSX some time....
I tried Megapeg (I downloaded the QT plugin), but I still can't export to a M2V file. The nearest I can get is a Toast-ready mpeg, which is fine, but I would prefer to be able to import into DVDSP for menuing, etc.
I heard about an app called MacMpeg2Converter 2.0, but the download link in Macupdate.com is dead, so I can't try it out.
Any other ideas... ? -
Thanks for that - I would probably give that a try if I had OSX installed, but I'm trying to find a solution under OS9.2
Any other ideas...?! -
Always helps to read the original message more carefully.
Bitvice, mentioned above, has been highly touted by many, but it's not free. -
Yeah, I just tried ouy Bitvice and it's doing the job perfectly... Thanks everyone!
Final Cut export to MPEG2?
By Alex_BGD in forum MacReplies: 11Last Post: 14th Nov 2011, 14:20 -
software for an imac
By marlo in forum MacReplies: 11Last Post: 13th Aug 2011, 09:49 -
DirecTV HD to iMac?
By jcoconnor in forum MacReplies: 0Last Post: 5th Apr 2009, 16:36 -
View\convert\edit *.mpg file (mpeg2) with an Imac
By drastus in forum MacReplies: 3Last Post: 8th Feb 2009, 18:58 -
Dell or imac
By fairytale00 in forum ComputerReplies: 17Last Post: 29th Mar 2008, 13:51
