is it possible to pause encoding in tmpge?
thankyou
only a start/stop function.
from TMPGenc's help file :
"Stop" Button
This button interrupts encoding of the current project. Once clicked, it may take some time for the encoder to cease because it must flush the GOP data and finish saving the stream up to the interruption point. It should be noted that once interrupted, the project cannot be continued without re-encoding.
note last sentence.. -
If you click stop, it will stop execting and pop up a dialog say ing 'abort encoding yes/no' (or soemthing to that effect). If you leave it alone, nothing happens. If you click No, it will continue to encode. So its a sort of pause, but you can't close Tmpgenc or reboot your PC or anything.Originally Posted by dvdhelpr
dvdplayer on pause
By steplock in forum DVD & Blu-ray PlayersReplies: 5Last Post: 15th Jun 2009, 16:05 -
video uploader w/ pause
By zoobie in forum Newbie / General discussionsReplies: 0Last Post: 1st May 2009, 23:16 -
Pause video using Avisynth
By roglopes in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2009, 15:41 -
Can you pause in MKVEtract?
By Maikeru-sama in forum Video ConversionReplies: 0Last Post: 30th Jun 2008, 09:55 -
how to pause at each subtitle line
By sallam in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2007, 06:16
