Well ive just done the walkthough and burnt a multi disc .... and Guess what Yippeeeee its done the job just as it says on the Tin![]()
However I noticed at the top of the auth screen a drop down for chapters and marked it to be made every 10 mins ... on the finished dvdr there were no chapters - so what do exactly do I have to do in order to create chapters .. to say im well impressed is an understatement chose the most tricky standalone I have in the house of the 3 and it fired up no problems at all
if anyone can just advise me on the above step im laughing
Thanks for looking in
em - I put the finished DVDR in the standalone and it started up with the menu I had created but there was no option for chapters .. what I mean is when I pressed forward to next chapter on my dvd the next part that came up was the VT that I had created at the start of Disc 2.. what i was expecting to see was a series of mini points at the 10 min intervals I had marked .. is this what its supposed to do ?
Can someone please advise on the above as I would realy like to be able to add chapter points with captures from the VCD into the resulting DVDR or if not then at least chapter points wereby I can at least jump to rather than having to fast forward ... is this possible with SVCD2DVD?
if it isnt then perhaps it maybe a good idea for the future -
Originally Posted by angel12
I guess it depends on what standalone you use. On the ancient X-Wave I have kept though it has a will of its own as to working at all, pressing Next brings me to the next chapter point. The Yamada DVX-6000 which replaced it, gives me the next VTS, like you.
There are, however, other buttons which I might try. Like > and < or the number buttons. It seems I must have a good read of the f***ing Manual..
Callan -
Thanks Callan for the reply
I wil give it a go and let you know never thought of using the other buttons Once again thanks for the reply if this works then im as happy as a dog in S**t
avidemux - x264/mkv with chapters? + aspect ratio question.
By simon_h in forum DVD RippingReplies: 2Last Post: 22nd Nov 2011, 14:13 -
good question about dvd chapters and workflow
By YOURCONNEXX in forum Authoring (DVD)Replies: 7Last Post: 18th Feb 2011, 17:32 -
Newbie question: menu and chapters
By cheerful in forum Authoring (Blu-ray)Replies: 0Last Post: 19th Dec 2010, 23:17 -
Chapters in ConvertXtoDVD. Have a question.
By KTV86 in forum Authoring (DVD)Replies: 8Last Post: 15th Oct 2009, 04:35 -
DVD Lab Pro chapters question
By jesterhud in forum Authoring (DVD)Replies: 9Last Post: 23rd Aug 2007, 18:06
