Hi,
I need some advice, please. I try to cut a svcd movie that I encoded with tmpgenc using tmpgenc tools in my XP system and I cannot use the slice bar to position in any part of the film It's stuck in the beginning. When I play the movie using mplayer2 I have the same problem but if I use WinDVD5 the problem disappears and I am able to position anywhere in the length.
If I play the same movie in a W2000 system it load the mediamatics mpeg-2 splitter filter and it plays normal. Could it be the not loading of that filter the cause of the problem. How do I force the load?
Thanks in advance.
