Hi,
I am based in India and we use PAL system here.I plan to buy a DVD recorder but confused with description given by webdealers.
Can anyone let me know which recorder RECORDS IN PAL FROM PAL SOURCE AND NTSC FROM NTSC SOURCE...ie firewire source or composite/svideo.
Will Panasonic E50 or Pioneer DVR7000 does it?
Do they have diferent model for Europe and USA?
Help will be realyy appreciated.I want to purchase from ebay.
Harchu
RECORDS IN PAL FROM PAL SOURCE AND NTSC FROM NTSC SOURCE....this is correct.
For instance...I have a Philips DVDR985(US Version) here in Germany. It now records in PAL format because it is in a PAL environment.
It used to record in NTSC in America....America is NTSC. -
Originally Posted by harchu
Usualy when recorder supports recording in PAL and NTSC, it means it will record NSTC signal into NTSC DVD and PAL signal into PAL DVD.
TV Tuner is usually only one. NTSC or PAL.Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Hi ,
Thanks for your replies..So which one should I go for ..that will record in NTSC from NTSC source and PAL from PAL source???Please let me know the company and model number.
Harchu -
Look at the JVC recorders.
Hi,
I think all models do not record in NTSC from NTSC source and PAL from PAL source.Panasonic has models for US which record only in NTSC and will not take PAL...Please confirm .
Do Pioneer models also are country specific that it record in NTSC in US and PAL in UK?
Harchu -
harchu, I was hoping that you will click on that link in my signature by yourself... so if you did not... please do so.... maybe you can find an answer there
Looking for sound card recorder (not Total Recorder)
By jimdagys in forum AudioReplies: 1Last Post: 7th Jan 2011, 19:23 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 04:54 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19
