Which is the best tutorial on this website if you were in this situation:
I have a dvd-+r/rw writer and a cdr/rw writer in my PC. I guess I am wanting to copy a full dvd to my hard drive and then burn it on dvd-r since I don't have a dvd reader besides the one in my writer.
Whats the best tutorial or tools to do this with?
Results 1 to 10 of 10
I don't think it really matters if your reader is rw or not, when you're ripping the dvd to your hd.
best guide for ripping files to your hd is here:
http://www.doom9.org/dvddec.htm#iso -
Correct, I know this, that wasn't the question I was askingOriginally Posted by dafreak
I did a pretty good job on my website as well
(URL in signature)http://encoding.n3.net <-- for all your DVD and CD backup needs! -
Hi all.
BrentD, it all depends what software(s) you intend to use.
If DVD Shrink, DVD Decrypter, Nero or burnatonce, I can highly recommend the guides at
http://www.dvdshrink.info/guides.php
I made them.
I think I know what you mean. Install AnyDVD and CloneDVD. The you put dvd movie disk in writer drive, wait till CloneDVD sets up files, then replace that disk with a blank DVD and burn. You don't need to rip to the hard drive separately. Look for tutorials under "DVD to DVDr using CloneDVD"
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Ok I tried the clonedvd, I placed the original dvd into teh dvd player/writer, opened clonedvd and did as the help file with it told me to do, it gets to 59% everytime and then I get an error which I have attached to this post. Any clue why I get this everytime?Originally Posted by tweedledee
Also if it does complete 100% will it ask me to remove the original dvd and put my dvd-r into the writer so it can write what it just copied?
Yes, it will ask you to remove the movie and insert a blank DVD. I use a DVD rom drive to read and put the blank in the burner so I can go away and pick it up when ready.
The problem you have is new to me, mavbe a really 'cluey' guy like "the Village idiot" or "FOO" or "tommyknocker" can help."Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Can I ask? Have you tried another DVD? Have you tried ripping with dvd-decrypter and loading that way (just to see if it works)
It may be a disk error due to a scratch."Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Yep I just successfully did my first rip and burn with another dvd, so it must be this dvd, it does have a few scratches on itOriginally Posted by tweedledee
Thanks everyone for your help, you are da bomb!!!!
video tutorial?
By greatveemon in forum Newbie / General discussionsReplies: 4Last Post: 12th Jan 2011, 08:20 -
New myDVDEdit tutorial
By myDVDEdit in forum MacReplies: 1Last Post: 17th Apr 2009, 21:14 -
avisynth tutorial
By pitaridis in forum EditingReplies: 1Last Post: 2nd Feb 2009, 07:46 -
EAC tutorial
By kippard in forum AudioReplies: 4Last Post: 25th May 2008, 04:06 -
imgburn tutorial???
By offensekilla in forum Authoring (DVD)Replies: 6Last Post: 30th Aug 2007, 04:49
